Gsync freesync and fps
Solved by Stahlmann,
- enable G-Sync in windowed and full screen
- enable V-Sync in control panel
- disable V-Sync in games
- set the fps limiter in control panel to 1 lower than your refresh rate (in your case 143)
- set preferred monitor technology to "G-Sync compatible"
Now G-Sync is working as intended. Neither G-Sync nor V-Sync will cause performance fluctuations. If that's happening it's normally the games fault.
