Corsair fans
Go to solution Solved by LukaP,
basically everywhere where there is any kind of obstruction, use SP fans. (so just use sp fans haha)
AF is Air Flow, for case fans.
SP is Static Pressure, for Radiators and Heatsinks.
If you don't know which you're using the fans for, get SP.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/137125-corsair-fans/#findComment-1821785
AF Series = More air flow
SP Series = More static pressure
^ There is your answer
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/137125-corsair-fans/#findComment-1821796
Don't forget that fans with good static pressure are good for filtered intakes! :P
waffle waffle waffle on and on and on
https://linustechtips.com/topic/137125-corsair-fans/#findComment-1821825
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/137125-corsair-fans/#findComment-1821847
