Does the msi mag forge 100r pc case have good airflow and good quality
Solved by HM-2,
14 hours ago, MohsenGamer11 said:Idk the features I want this board has them so I'm not getting anything else
You really should consider other options, because it's not a particularly good board. The only reason to go X570 is if you want multiple PCI-E 4.0 SSDs. Your build doesn't even list one!
huckk ·
Posted in Laptops and Pre-Built Systems2 -
3
2
DudeSquad11 ·
Posted in Troubleshooting7 -
9
2
percemis ·
Posted in New Builds and Planning7 -
7
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
