If you have enough budget or can get GPU for lower price, this is the best in my opinion.
https://au.pcpartpicker.com/list/9sLhht
Due to GPU's being priced too high, You might also go with ryzen 5700G, Defending on what tasks you doing, But I doubt integrated GPU will be enough for premiere...
You also can go with this route
https://au.pcpartpicker.com/list/Nsh4Hz
But maybe you can get 3060 for better price somewhere and build 1st system.
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965805
16 minutes ago, DariusG said:
Budget: $1500 AUD (Feel free to go a little over if it will greatly increase the specs)
Country: Australia
Programs: Adobe Premiere Pro - 1080p and just some random DAW's for Music Production
(PC PartPicker list would be great!)
Made it a bit hard for myself but i got 3070 in this price range.
PCPartPicker Part List
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  ($239.00 @ PLE Computers)
Motherboard: MSI MAG B560M BAZOOKA Micro ATX LGA1200 Motherboard  ($109.00 @ Centre Com)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($120.20 @ Amazon Australia)
Storage: Western Digital Blue 1 TB M.2-2280 Solid State Drive  ($132.29 @ Amazon Australia)
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card  ($800.00)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  ($57.00 @ Zotim)
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.00 @ PCCaseGear)
Total: $1606.49
Generated by PCPartPicker 2021-09-01 22:10 AEST+1000
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965814
Thank you so much for your help, I was planning to purchase a 3060 as well....
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965817
Just a little difference but better : Intel :https://au.pcpartpicker.com/list/LXY4Hz
Amd : https://au.pcpartpicker.com/list/RRg8p2
The psu is better bang for the buck
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965866
PSU is only 10$ difference, So that's nothing you can say 😅
And you should definitely avoid WD Blue SN550 at any cost right now. They are changing parts and making drive around 50% slower...
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965997
Total: $1606.49
If it's possible to get 3070 for 800$, It definitely fits the budget and is best option.
I said it in reply above, Avoid WD blue at any cost.
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14965999
But i didnt? I used the older 3D TLC model in this one.
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14966003
if you are willing to scale back on the memory rgb you could definitely go for something a bit cheaper and you could probably go for 32gb of ram unless your doing some very intense editing. also for the cpu cooler i might get a cooler master 212 who black with a noctua fan or a be quite pure rock 2 with a noctua
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14967082
  • Get a better cooler
  • I'd get a larger SSD
  • You can probably get a better price for a Quadro or similar card
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14967268
A thought anyway.
An 11700f should be cheaper and nearly the same speed. With that  You won’t be using the iGPU anyway with the 3060. Of course the price difference may not be much.  I don’t know.  I don’t know if the 11700 stuff comes with a stock cooler or not. If it does it will do fine since you can’t overclock anyway, and there’s another bit of money that doesn’t need to be spent.  Hardwareunboxed did an interesting piece on b560 motherboards where they found that some were much faster than others.  I don’t know where your particular board lands on that but it might do with looking into. might need that money for a different motherboard.  My memory was the faster ones were more expensive.  I have no opinion on the memory one way or the other.
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14967393
6 hours ago, Dr0idGh0sT said:
I did go over your budget I think, But if you can afford, This is better system.
https://au.pcpartpicker.com/list/7bhsdD
Also, Get a montech X3 mesh case, Or any mesh case for better cooling.
His case wasn’t too bad if he used the mesh front panel rather than the glass one.  A liquid cooler more or less makes cooling semi moot anyway. That is a hotter cpu.  Too hot for his original cooler choice.  I don’t know what the cheapest available cooler capable of cooling it is. If that’s it, that’s it.  There are some bigger air coolers that would also do it.  I don’t know if they’re cheaper or not.  They absolutely would require the mesh front though.
edit:
Gah.  This thread has changed a whole lot since I first saw it.  Price went from 1000-1500, the original list that had a 10900 on it is gone, and I’m like 6th post rather than second.  This may not apply
Edited by Bombastinator
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14967782
edit:
I also value aesthetics, So that's why I pick liquid cooler over air one, I don't really like how those tower coolers are looking 😄 But it's personal preference and good air cooler definitely cools better than cheap AIO.
https://linustechtips.com/topic/1369862-pc-part-build/#findComment-14969031
