Is spanned or striped volume more safe and reliable?
cwgzz
I can’t seem to find anything on Google about this. I know that striped volume offers better R/W speed since the data is stored on hard drives as if it’s one hard drive… but I can’t seem to find anything if striped or spanned is safer?
in terms of wearing out the life span of a hard drive, is spanned or striped better? That’s what I really want to know? Does spanned or striped causes a failed hard drive faster? I’m not sure how to ask this question but hope someone can understand. Thank you
<-- Moved to Storage Devices -->
Please ensure when creating new threads you're selecting the appropriate subforum.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Neither will affect life span of the hdd much.
The spanned lets you mix drive size, the stripped gives you better speed. With both if one drive dies you lose all the data.
Id also suggest using storage spaces in windows normally.
I have been doing a bunch of research on this and it seems that only using a striped volume will result in losing all of my data if one HD fails because it splits data on both drives.
But using a spanned volume, I won’t lose all my data if one HD fails. A spanned volume works by filling up the first HD first, then once there’s no more storage, it’ll then start using the second HD. So if one HD fails, I can still get the data from the HD that didn’t fail.
Neither method will impact the live of the drive in any observable way.
You always have the risk of if 1 drive died, you may lose access to everything depending on how it's written.
Just keep them as separate volumes.
yes, but any spanned data across the drives will be affected if the first drive dies. depending on the types of files written, you may not be able to access them again by simply plugging it into another PC and just pulling the data off.
Nope you still lose all the data with a spanned volume. Its doing it on a block level, not a file level. Recovery might be a bit easier, but you should never rely on file recovery.
If you want to have it so if one drive fails you only lose have the data, just have seperate drives. You can make it look like one with something like drivepool.
So the chances of a HD failing using a spanned or striped volume is the same as just one HD on its own storage failing?
Yup, or very close. Hdds should last many years under normal use.
Quote
Spanning
In theory yes. But the two (or more drives) are presented to the OS as one big drive (volume), so who knows where it actually writes what. I think it would depend on the OS's implementation of spanning. I personally don't see a good use case in the modern day for using spanning.
Is it really that hard to just install or store files on the other drive. Is it really that annoying to see C: 1TB and D: 1TB or sda 1TB, sdb 1TB in the OS as opposed to C: 2TB or sda 2TB in the OS? Spanning just lumps the space into one logical drive/volume and presents that to the OS. It is more of an organizational scheme.
Spanning comes from the old days when drives were much smaller, so you could pool them together into one larger drive to install large applications or databases, on a server that many people would access. I don't see much benefit or point in pooling storage these days, at least not without having redundancy. Most Enterprises use some form of RAID these days.
Striping
Assuming 2 drives (there could be more), striping writes block 1 to drive 1, then block 2 to drive 2, then block 3 to drive 1, block 4 to drive 2, etc... It is used for performance purposes, but it is risky because there is no redundancy.
With modern, fast and large SSD or nvme drives, there isn't really much of a point to use striping (to get redundancy, use RAID 10 instead) in a single user system. Are you planning on running, tuning and optimizing a massive database to be served out to the planet or something? If not, it isn't going to make your Call of Duty run that much faster on modern hardware lol.
The point of real RAID is redundancy. Striping by itself is not redundant. Lose a drive, lose all the data.
Neither configurations seem "safe" to me.
Perhaps try googling "RAID levels", "understanding RAID", or "how RAID works". You'll get tons of information.
Unless you are only concerned with R/W performance (probably negligible in a modern, single user, home system) and not concerned about redundancy (and make frequent backups) go ahead, use striping. If you want "safety" use  RAID 1 (mirror), RAID 10 (mirror with striping) or RAID 5 (striping with parity) as these RAID modes can recover from the loss of a drive. Let's be honest, all drives will eventually fail, whether it be a spinning disk, USB flash drive, SSD or Nvme. It's a matter of when, not if. (Murphy's law says it will be at the worst, most unexpected time too lol).
Also, RAID is NOT backup, so you should always still have and utilize a good backup strategy regardless of the drive or RAID configuration you decide to use.
Again, IMHO, Spanning and Striping are practically useless for most cases. Especially for a single user, home system.
23+ yrs IT experience
MAIN SYSTEM
Operating System
Windows 10 Pro x64 21H1
Case
Antec Three Hundred Two Gaming
CPU
AMD Ryzen 9 3900X 3.8GHz 12-Core 24-Thread
Motherboard
Asus ROG Strix X570-E Gaming
RAM
G.Skill Trident Z RGB Series 32GB
(2 x 16GB) DDR4 3200 (PC4-25600)
Graphics Card
Asus Nvidia Geforce RTX 2060 Overclocked (Factory) 6GB GDDR6
Dual-Fan EVO Edition
Storage
2 × Samsung 970 EVO Plus Nvme (M.2 2280) SSD 1TB
2 × Samsung 860 QVO SATA III 6.0Gb/s SSD 1TB (RAID1 Array 1)
2 × Hitachi UltraStar HDS721010CLA330 7200RPM SATA III 3.0Gb/s 1TB (RAID1 Array 2)
PSU
Thermaltake Toughpower GF1 850W 80+ Gold
Optical Drive
LG WH16NS40 Super Multi Blue Internal SATA 16x Blu-ray Disc/DVD/CD Rewriter
Displays
HP w2408 widescreen 16:10 1920x1200 @60Hz
HP w2207 widescreen 16:10 1680x1050 @60Hz
Keyboard/Mouse
Logitech MK200 Wired Keyboard/Mouse Combo Kit
Maybe in a home, single-user system under low workloads. Enterprise is a totally different situation, drives fail all the time in Storage Array Systems under heavy load. Hence the reason why those Enterprise Storage Systems use RAID and can cost millions of dollars.
MAIN SYSTEM
Operating System
Case
CPU
Motherboard
RAM
Graphics Card
Storage
PSU
Optical Drive
Displays
Keyboard/Mouse
Depends on the workload. The more a drive is read/written to (especially true of traditional spinning disks) the more heat and stress on the drive, which ultimately leads to drive failure. Drives are going to fail, it's a fact of life. I wouldn't be paranoid about it.
The more important concern would not be so much about the impact on the life of the drive, but rather how easily and quickly a drive failure can be mitigated without any data loss.
Thus, a good backup strategy and perhaps a fault tolerant setup (some form of RAID) would be appropriate.
MAIN SYSTEM
Operating System
Case
CPU
Motherboard
RAM
Graphics Card
Storage
PSU
Optical Drive
Displays
Keyboard/Mouse
