Gigabyte/asus compatibility issues
Solved by Analog,
If someone was to tell me this, I would seriously consider not buying from that store... But seriously, this is why shopping online is usually preferred. This way you can avoid uneducated and at the same time pushy sales reps.
To the question at hand, as it was already mentioned, compatibility stems from the standard a specific component uses in order to connect to another component. In this case the graphics card uses a variation of the PCIe interface (whi generation exactly is besides the point due to backwards compatibility) and if a motherboard has this same interface, said graphics card can be plugged it and it will work.
