So i have a question about mounting HDD's in be quiet dark base 900. When I screwed my drives, they are kinda held in place by rubber grommets, but it for sure is not a tight fit, screws are not holding it rock solid in place and I can wiggle those a little bit. Is it normal with those rubber mounting systems? More importantly is it safe? Or am I installing it wrong.
https://linustechtips.com/topic/1368648-dark-base-900-hdd-mount/
It is this way to absorb the vibrations from the hdd. If its not able to move freely or shake lose then I'd say its working as it should.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
