Aorus X570 ELITE --- possible fan configuraton?
Solved by Skiiwee29,
5 minutes ago, JayJayJedi said:@Skiiwee29 Well, thank you for you input....according to the specs...F12 uses 0.08A & F14 uses 0.11A, which I guess should be fine. And regarding that CPU_OPT header, could I use that as well just for the fans? I have no intention to use water cooling.
Yep, perfect on both ends.
Featured Topics
nulcow ·
Posted in Laptops and Pre-Built Systems1 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
HyperPalBuddy ·
Posted in Audio0 -
1
wyndwalker ·
Posted in Power Supplies2 -
okkee ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
