PSU Shroud vs triple front fans
dmmsta
Go to solution Solved by Ralfi,
These are some GPU Load tests I did a few months ago as I was putting together a new triple fan setup in my Corsair 4000D case…I’ve changed my fan profiles since then, so take what you will from these results…
1 front fan actually provided the best temps for some reason - I didn’t have a room temperature meter on me then, so the ambient temp may have impacted things…
Anyway, hope it helps…
3 x Front fans-GPU under load
‘Quiet’ Fan Profile for CPU/Case fans. GPU fans @ default restricted PWM threshold (66%)…
  • CPU (120mm x1); 1010RPM
  • Rear exhaust (120mm x1); 642RPM
  • Top exhaust (120mm x1); 635RPM
  • Front intake (120mm x3); 567RPM
  • GPU (80mm x2); ~1567RPM
Noise: 39dB Average
Temps: 98° (GPU Hot Spot), 86° (GPU), 42° (CPU)
2 x Front fans (upper & middle)-GPU under load
  • CPU (120mm x1); 1009RPM
  • Rear exhaust (120mm x1); 635RPM
  • Top exhaust (120mm x1); 636RPM
  • Front intake (120mm x2); 564RPM
  • GPU (80mm x2); ~1500RPM
Noise: 39dB Average
Temps: 99°, 85°, 42°
1 x Front fan (upper only)-GPU under load
  • CPU (120mm x1); 926RPM
  • Rear exhaust (120mm x1); 549RPM
  • Top exhaust (120mm x1); 544RPM
  • Front intake (120mm x1); 549RPM
  • GPU (80mm x2); ~1290RPM
Noise: 38dB Average
Temps: 95°, 83°, 39°
No Front fans-GPU under load
  • CPU (120mm x1); 983RPM
  • Rear exhaust (120mm x1); 628RPM
  • Top exhaust (120mm x1); 602RPM
  • GPU (80mm x2); ~1418RPM
Noise: 38dB Average
Temps: 97°, 85°, 44°
Wondering if anyone can comment on the impact of a triple front fan arrangement, with a case that has a PSU shroud.
I'm considering a Phanteks P400A RGB, which comes with 3 front fans OOTB.
The case has a PSU shroud, and I'm wondering if this impacts the value of the 3rd (bottom) fan?
Assuming that the PSU is installed with the inlet fan face down (and the exhaust obviously rear facing), is the 3rd fan at least 50% redundant.
Although there is a hole in the roof of the shroud next to the fan, it appears that most of the airflow will go to the dead space under the shroud.  While I can see this a benefit if spinning disks are installed where the HDD cage is I won't be using this (and removing it to allow for better cable mgmt).
I imagine that the airflow into the "dead end" space would cause counter-productive "turbulance" in the case (I have no aero-dynamics knowledge so just my assumption).
Comments appriciated.  I'm thinking that 2 fans up front would provide better, or at least more directed airflow to the GPU / CPU...
Wanderer of the Internet.  Gamer of Games   Father of three
Relearning self-building, so please excuse the n00b questions for a while...
I think you're overthinking it.
Yes that 3rd fan is mostly for the hard drives, no it's not going to make that noticeable of a difference, maybe measurable, but that's it.
If it came with 3 fans, use the 3 fans.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
Noise: 39dB Average
Noise: 39dB Average
Noise: 38dB Average
Noise: 38dB Average
Thanks for the info both.
had a feeling I might be over thinking a little
