Budget (25k - 30k egp):
Country: egypt
Games
Other details (GIGABYTE Z590 UD AC mother board , Intel Core I5-10600K ,ADATA FALCON 512GB M.2 Nvme ssd , Noctua NH-U12S-Redux (CPU AIR COOLER) , MSI RTX 3060 GAMING X 12GB , Cooler Master MWE 650 V2 80+ GOLD , Corsair Vengeance PRO RGB 16GB (2X8) 3600 CL18 😞
this is a build  im thinking about buying but i dont know if its the best bang for the buck so what do you think guys is this ok should i change anything let me know thanks
https://linustechtips.com/topic/1366383-mid-range-build-opinions/
Low storage with an expensive motherboard. Not a great combination. I'd also just get a non k i5 if the price is a big difference and get a h series board saves you money and they you can get more storage and preferably not that ssd.
Also what case are you using? Do keep in mind that the 10600k does not support 3600hz without you manually trying to get it to work. SO memory will at stock run at a lower frequency.
i do have 2 hdd 1tb each but i forgot to include them so about the ssd any idea what i can get instead and i got that mother board becuse i know that the 10600k needs a z590 to overclock it and about that ram idk i cant find any ram with less that 3600hz
23 minutes ago, Alireza said:
hi my friend
you dont need z590 board for a 10600k
its a bit too much
also i would've gone with 16GB 3200 MHZ CL14 if i were you
other then above its a nice build if you can find the gpu at MSRP
what ram would you get if you were me and what mother board would be enough for the 10600k
i just checked the prices and based on those
you don't need motherboard upgrade
the ram price is different in each country but this is my favorite kit
if you cant afford the extra its fine and your chosen parts will serve you well
https://www.amazon.com/Crucial-Ballistix-Desktop-Gaming-BL2K8G36C16U4B/dp/B083V93HJG/ref=sr_1_1_sspa?dchild=1&keywords=cl16+3600mhz&qid=1629435356&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExVEUwRlNHVlFUUFQ0JmVuY3J5cHRlZElkPUEwMzg1ODI2MTlEMVI3MTNLUUNPQyZlbmNyeXB0ZWRBZElkPUEwODU2NzAwMjI2Qk1CRjZTWVMwViZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
