UDK Crashing Issue. (To do with Build lighting / a Material)
SuBw00FeR
Didn't really know where else to ask, so here goes, I'm doing a course atm which has us using UDK, for the most part it's working fine but I've run into a snag, basically when I try to build the lighting with Static Meshes checked UDK crashes (and obviously doesn't build the lighting nor save it) I've had a look through logs and this is what I have found (Keep in mind I don't actually have any Static Meshes currently, as I'm very early on in my course.)
Now I'm assuming it's an issue with my landscape_material_01 but I'm not sure what, as I have everything connected appropriately (as far as I can see) Here's an Image of it so you can see, I don't believe i've missed anything but I might have. ZawpwcD.png
[0230.79] Cmd: MAP LOAD FILE="D:\UDK\UDKGame\Content\Custom\landscape_tute\landscapeMaterials.udk" TEMPLATE=0[0230.84] Log: Encountered missing default brush - spawning new one[0230.96] Log: -- Checking Building LODs[0230.97] Log: Primary PhysX scene will be in software.[0230.97] Log: Creating Primary PhysX Scene.[0230.97] Log: Finished looking for orphan Actors (0.002 secs)[0230.98] Cmd: MAP CHECKDEP DONTCLEARMESSAGES DONTDOSLOWREFCHECK[0231.13] Cmd: UpdateLandscapeEditorData[0236.59] Log: Deterministic lighting is ENABLED[0236.59] Log: 	Lighting will be slower to complete...[0236.62] Log: Static lighting kd-tree: 0 vertices, 0 triangles[0238.47] Critical: appError called: Couldn't find Shader TBasePassVertexShaderFDirectionalLightMapTexturePolicyFNoDensityPolicy for Material Resource landscape_materials_01!		With VF=FLandscapeVertexFactory, Platform=PC-D3D-SM3 		ShouldCache: Mat=1, VF=1, Shader=0 		Material Usage = MLM_Phong, BLEND_Opaque, bUsedWithLandscape[0238.47] Critical: Windows GetLastError: The operation completed successfully. (0)[0240.38] Log: === Critical error: ===Couldn't find Shader TBasePassVertexShaderFDirectionalLightMapTexturePolicyFNoDensityPolicy for Material Resource landscape_materials_01!		With VF=FLandscapeVertexFactory, Platform=PC-D3D-SM3 		ShouldCache: Mat=1, VF=1, Shader=0 		Material Usage = MLM_Phong, BLEND_Opaque, bUsedWithLandscapeAddress = 0xfccd940d (filename not found) [in C:\Windows\system32\KERNELBASE.dll]Address = 0x400b8dd5 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x40075e26 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4024720a (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x408cd406 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4090e7c3 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4090f39a (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4090fb62 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4090fc6b (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4097531d (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x409333cb (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x409608b2 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x40968aee (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x402868c5 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x40ada71e (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x403792a4 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x40a9027b (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4039eddb (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x4056014a (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x408279e2 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x41267af7 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x41267d92 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x40cece06 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0xc21c33   (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_vc_custom_64.dll]Address = 0xc22373   (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_vc_custom_64.dll]Address = 0xc22430   (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_vc_custom_64.dll]Address = 0x8009fe16 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x8009406d (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x800ef13c (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x800cb723 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x80104f56 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x76c09bd1 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c072cb (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c06829 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76d411f5 (filename not found) [in C:\Windows\SYSTEM32\ntdll.dll]Address = 0x76c0685a (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c03838 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c06bad (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0xfb4af96d (filename not found) [in C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll]Address = 0xfb4b12e1 (filename not found) [in C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll]Address = 0xfb4b03d2 (filename not found) [in C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll]Address = 0x76c09bd1 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c03bfc (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c03b78 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x8010162b (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x80106b1f (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x800f12dc (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x80104f56 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x76c09bd1 (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x76c098da (filename not found) [in C:\Windows\system32\USER32.dll]Address = 0x800c52c5 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x800c56b6 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x800c5399 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x8000413e (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0xc3dc23   (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_vc_custom_64.dll]Address = 0x800d6cc4 (filename not found) [in D:\UDK\Binaries\Win64\wxmsw28u_core_vc_custom_64.dll]Address = 0x415bb0cb (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x415bb18a (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x95ca16d4 (filename not found) Address = 0x95c51ee8 (filename not found) Address = 0xf5271b5a (filename not found) [in C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll]Address = 0x95ca124e (filename not found) Address = 0x872ba6   (filename not found) Address = 0x3fe30000 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]Address = 0x3fe30000 (filename not found) [in D:\UDK\Binaries\Win64\UDK.exe]
If anyone is curious, here's how I fixed it.
Well my tutor has fixed it, if anyone is getting a similar issue this is how he fixed it:
Create a New Material, name it something new, Copy the entirety of the old Material nodes, paste them into the new Material, and hook them up again to diffuse and normal, then make sure you edit your landscape properties to have the new material as the Landscape Material. After this I was able to rebuild the lighting using lightmass and Static Meshes.
Absolutely zero idea what caused the issue, but that fixed it for me.
