Hey guys, ive been looking at headsets that were pc / ps4 compatible, an thought "couldn't i use almost anything with the aux jack in the controller". I then realized that it may only do stereo over dolby surround, so thats what i want to know , does it output dolby surround?
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
No, the PS4 controller only offers 2-channel audio output. However, keep in mind that you only have two ears. You only need two audio drivers for headphones - any headphones that advertise 'true' surround or anything like that are just using marketing gimmicks to hide their shortcomings. :)
"Be excellent to each other" - Bill and Ted
Community Standards | Guides & Tutorials | Members of Staff
You only need dolby surround when running things like 5.1 and 7.1 systems, that means the PS4 can distinguish the different speakers and send the correct audio to each speaker (rears, fronts, centre, sub)
headphones only have 2 speakers, therefore stereo is all you need (left, right)
then what are 7.1 headsets and 5.1 headsets
My Rig
Total: $2074.22
In most cases they are software surround sound done through processing, in others they are a combination of smaller drivers resulting in a "surround sound" effect. In most cases though you end up with a poor representation of audio quality when compared to two dedicated large drivers.
MY BUILD | Intel i7-3770K @ 4.5Ghz | Corsair H115i | MSI Z77A-GD55 | 2 x ASUS STRIX GTX 970 SLI | Corsair Vengeance 16GB LP 1600Mhz | Intel 330 180GB SSD + 2x Seagate Barracuda 1TB + 2x WD Red 2TB | OCZ ZX 850W 80+Gold | NZXT H442 Razer Edition | LG 34UC88-B 21:9 3440x1440 | Razer Kraken | Razer Blackwidow Ultimate 2013 | Razer Naga 2013 | Logitech Z-2300 | Steam/Xbox Live Gamertag: Jay Slasher
Gimmicks. Anything with multiple drivers in a single cup is a gimmick, plain & simple. Any decent set of stereo headphones + virtual surround sound software will do a better job.
The reason is that when you hear sound in 3d it is because of the way your brain is interpreting slight differences in what each ear hears. In the real world the shape of your head, the shape of your ears & the distance between your ears all play a factor in the slight differences heard by each ear.
In virtual surround this is simulated by applying a head-related transfer function (HRTF) to the sound in an attempt to simulate this effect. With headphones that have multiple drivers per ear you miss out on all that, relying only on the position of the tiny drivers in relation to your ear which doesn't do anywhere near as good of a job.
On top of them sucking at reproducing surround sound they also suck at reproducing any sound. Reason being is instead of having a single, large high-quality driver you have 5 or so little crappy ones.
Edit: This video is a perfect example of how you can get 3d sound using stereo headphones. Headphones are required for this to work:
CPU - 3770k @ 4.7GHz | Motherboard - Asrock Z77 Extreme4 | RAM - Crucial Ballistix Sport 16GB @ 1600 | GPU - EVGA GTX 770 SC ACX (2x SLI) | Case - Coolermaster HAF XM | Cooling - CM EVO 212 | Storage - Corsair Force 3 90GB | WD 2TB x 2 | PSU - Thermaltake SMART 850W | Display - Asus VG248QE 144hz + GSYNC kit |  Mouse - R.A.T. 7 | Sound - Creative Titanium X-FI HD | DT990 | ATH-M50 | ATH-AD700
but i like to play fps games so surround is better for me, so is there anyway to get dolby surround in a headset
My Rig
Total: $2074.22
Although sound cards are pretty much anathema here at LTT if you really want virtual surround sound they're kinda worth it for that IMO.
Here's a video showing all the different virtual surround sound options. I personally prefer CMSS-3D over all the other ones. All the other solutions sound like youre inside a room or something because of the reverb:
Still better off getting a nice pair of stereo headphones & something like a creative card with CMSS-3d or an asus Xonar sound card with dolby headphone instead of buying a headset with all that built in. Headsets just tend to be overpriced & lower quality than you would get if you bought a pair of headphones & a cheap clip-on microphone.
i want to use them on ps4 and pc
My Rig
Total: $2074.22
Im not sure you understand. Surround sound only works properly when you are using more than 2 speakers, so that sound from behind comes from speakers situated phyiscally behind you, sound from the front left for example comes from the front left speaker, and so forth
Headphones only have 2 speakers, however a proper stereo image will still give the illusion of surround sound. using stereo headphones I still never really struggle to pinoint enemies, the difference is slight at best
There are so called surround headsets, ones that use multiple speakers in the headset , like say 5 speakers in each ear but honestly you cannot tell, the speakers are so close together, it may aswell just be one big speaker
yeah i dont understand what your saying, i just want 5.1 or 7.1 surround
My Rig
Total: $2074.22
You cant do that through through headphones -  5.1 literally means 5 speakers, 1 subwoofer,  - headphones that say this on are just simulating it, but the PS4 controller cant do this - you either need to connect a surround sound headset to the back of the console, or stick to normal headphones plugged in the controller
ok im fine with somthing that just simulates it and i will prob go with some astros or something for it and thanks for helping clearing that up to me
My Rig
Total: $2074.22
