Well, I love my CX430M. But the fan is terrible. The bearings are already shot in it, and whenever you bump the case, it stops spinning. I need a replacement fan for it, since I don't want it to die. And I don't care about the color at all. I don't know what size fan it has either, so...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/
Don't think you can but don't shoot me if I am wrong
edit: sounds like a motor problem
shoot this man he's wrong
Intel i5 4670K 3.4GHz | EVGA 780Ti Classified | ASUS Gryphon Z87 w/ Armor Kit | G.Skill Sniper 8GB @1866MHz
Samsung 840 Evo 500GB | Seagate Barracuda 3TB | Kingwin Lazer 850W Bronze PSU | Corsair 350D Window
Razer Blackwidow Ultimate BF3 Edition | Razer Naga Molten
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1814979
It's bearings. I know that sound. Hey @MG2R, didn't you replace the fan on one of these?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1814992
The CX430M uses a 120mm Yateloon D12SM-12 fan.
I think mine is a Nidec. And now I know the size.
What Noctua fan would you guys recommend for this application?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815007
Is it still under warranty?
I'd spend more RMA'ing it. It would be cheaper to get a nice Noctua fan for it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815020
Another possibility would be putting more lubricant in the fan bearing. That might fix it for awhile.
My rig: 2600k(4.2 GHz) w/ Cooler Master hyper 212+, Gigabyte Z68-UD3H-B3, Powercolor 7870 xt(1100/1500) w/AIO mod,
8GB DDR3 1600, 120GB Kingston HyperX 3K SSD, 1TB Seagate, Antec earthwatts 430, NZXT H2
Verified max overclock, just for kicks: http://valid.canardpc.com/show_oc.php?id=2609399
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815047
Meh. I'd rather buy a new fan and forget about it.
EDIT: And I don't have any lube to use on it. xD
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815050
Heck, try dropping some vegetable oil in it then :P.
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815064
My dad would not allow that to happen. Again, Noctua is the easy way out.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1815068
See:
This how to do it.
Also just get this fan if you don't mind the LED. http://pcpartpicker.com/part/cooler-master-case-fan-r4l2r20acgp
Although, if you're contemplating on doing this, my current advise would be to break out the ENTIRE fan connector and cable to the motherboard. That way, you have absolute control over the fan. Just dump an NF-F12 in there and make it run at ~400 rpm. Should be good and about as quiet as an actively cooled PSU can be. To give you an idea, I'll make a video with the sound. Give me a minute here.
EDIT:
EDIT2: To hear the desktop at full load with the Noctua fans cooling it, check out
https://www.youtube.com/watch?v=LInNjI75VLM
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816109
See:
EDIT:
Whoops, blew right over the video he posted. :P
Now, I should be able assume you can answer this as well: Can I take the connector off of the PSU's PCB so I can just plug the fan in? I have no more places left for fans on my motherboard.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816584
I would advise AGAINST messing with the connector on your PSU PCB. Just cut the wires from the fan and solder the new connector on to them.
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816602
This just made everything a thousand times harder. I could probably pick up the things I need to solder and do moderately good for my first time, but we don't have anything needed to solder. :(
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816679
Then just twist the wires together and put heat shrink over it... Should be fine.
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816700
I never thought of it and it's so simple. xD I'll go order an NF-F12 when I go back to my mom's, along with some NH-T1.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/136573-need-to-replace-psu-fan/#findComment-1816933
