Bluetooth sound system suggestions
I've been looking into setting up a sound system in my kitchen for a while now but can't really settle for anything.
Only requirement besides decent quality sound would be Bluetooth support and the possibility to wall mount. Price wise I set the limit around 700€, but I'll probably look through the second hand market anyways, so msrp isn't that relevant.
I would really appreciate any suggestion or input in general since I'm completely unfamiliar with the topic.
https://linustechtips.com/topic/1365531-bluetooth-sound-system-suggestions/
Well any generic amp and speaker setup will work. You can easily make any audio device bluetooth with a simple bt to 3.5mm adapter.
So really it comes down to your sound qualtiy requirements as I often go to my local used goods stores and stores comparable to goodwill in the usa. Often a amp is around 50€ tops for a nice one ones that still have their remote cost more. Passive speakers go for 10 a piece there often just google the model and see what kinda quality they are.
New you can also just get a killer setup too options are endless.
All in all what I recommend is passive speakers with a amp somewhere if you want to have the speakers far apart because you can decide how long the cable has to be then. Then just hook a bt to 3.5mm jack thingy up to it and call it a day. Basically that simple bt thingy makes stuff from the decades before modern and easily usable with any wireless device.
Thanks, I'll look into that c:
