Corsair MP600 (OG) vs MP600 Pro
Sarra
First off, this is more about curiosity, not about 'should I bother spending another $400 to upgrade'.
So, I noticed in a recent video on LTT that Linus mentioned that the MP600 they were using was older, with slightly under the rated speed for the PS5.
Having a MP600, my curiosity piqued by this. I looked it up on my Newegg order history, and sure enough, I have the OG MP600.
So, I was comparing the MP600 with the MP600 Pro, and I noticed that the throughput was higher on the Pro, 7,000MBps vs 4,900MBps or so for the OG. But the IOPS is actually higher on the OG than the Pro version.
For gaming, and more importantly, video editing, does this mean that, theoretically, an upgrade isn't really worth it? I guess I'm not quite sure how the IOPS vs Throughput effects real world performance.
The end result, for me, is that this drive is more than fast enough, and I'm not spending another $400 to replace a 5k MBps drive with a 7k MBps drive.
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
1 hour ago, Sarra said:
For gaming,
no.
video editing,
if you run the preview windows at 8k 60fps, sure it will help. other than that, it wont help.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
It's either edit off the MP600 or a 4TB 5400 RPM storage drive, or even worse, over my network off a 2TB 5400 RPM drive. I'm planning on replacing the 2, 3, and 4TB spinning rust drives with 10TB drives, but I'm hoping the pricing will drop a little first.
