My 60 Hertz monitor looks more clear than 75 hertz (blurr)
Darvin0001
Sometimes higher refreshrate can cause pixel error making some pixels to not output the correct color.
BTW, probs worth explaining, your screenshots all look identical on our monitors, as we're all viewing them at our own native resolution and refresh rates.
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
Man, that's an old VGA panel. I wouldn't be surprised if the board can't reliably handle 75Hz any more.
If the monitor is barely fast enough for 60Hz and you use it at 75Hz it will look blurrier, as the pixel response times and refresh rate are out of sync. (The screen wants the pixel to change colors before it is finished changing to the correct color of the previous frame)
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
