ryzen 5 3400g Best CPU Fan for Quiet and also Low temps for AMD Ryzen 5 3400g with Radeon Vega 11 Graphics (Perhaps as well good system fans)
Solved by RONOTHAN##,
Just now, Yumekizawa said:Alright alright, thanks alot man, i'll probably be going for that noctua NH-U12s or the hyper 212, however since I am also currently planning for improving or upgrading my CPU I may just go ahead and buy the NH D15. Other than that, thanks alot
I wouldn't buy a new CPU with that motherboard. Most if not all of those A320 boards are made as cheaply as possible and tend to die and have weird instability problems with anything but 1st gen Ryzen. If you're gonna upgrade, it will be worth it in the long run to just get a new motherboard at the same time.
That being said, unless you're going for an 11700k or a 5800X, you probably don't need the NH-D15 and the NH-U12s will be more than enough.
