Hi i have a pc with asrock b550m pro4 is it worth to go on asrock b550 extreme4?  I wanted a bit more rgb....
And i have r7 3700x with stock cooler AMD i am reaching 75~80c on load what cooler would be good to keep it between 55~65c i am thinking about nzxt x72 is it any good ? Can find used arround 100€ new one is arround 220€.Or is there maybe cheaper solution? Water or air cooling makes no difference for me. Arctic vrezier 50
looks good as well. Just is it good enough to keep it cool the cpu?
https://linustechtips.com/topic/1359779-small-question-to-pro-ppl/
The extreme4 looks like it was overall better so, if you have the money, i guess why not...
But i see no reason on buying a better board if you already have a completely build system and it's good for you (except of course your need of rgb)
As for coolers probably get ethier scythe fuma 2 or noctua nh-u12s redux for a lot cheaper
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Thanks ... i was thinking i can add rgb ram and than i have more rgb ... with mobo i can pass
Thanks gonna check up the coolers
17 minutes ago, Radza266 said:
Can find used
I would never recommend buying a used AIO, you never know if/how it was used/abused.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Rgb ram will work regardless of motherboard, if your mothboard doesn't have rgb header/pin or software then the ram rgb Will work with their included software, if it is CORSAIR you have icue and g.skill you have the gskill software
I don't see a point in upgrading to a slighly better motherboard, I think this would be a bit of a waste of money given very mininal gains. Just get a new air cooler from noctua, it will deliver great performance without the added complexity and risks of a used aio.
42 minutes ago, Freakwise said:
rgb Will work
unfortunately, i can confirm this…
yeah, but it doesnt work… "no RAM detected please contact us to start the RMA process"
… lol seriously  how effed up must their software be if *thats* their error message ?
btw the RAM works fine obviously, except its kinda really rgb'ish 🤢
-Scott Manley, 2021
