I bought a used PNY XLR8 1660 Super in March for my first PC, and about a week ago it started making a very noticeable whine through my speakers when I played certain games. I tried to just ignore it at first, but eventually I deduced that it was load related, as limiting my framerate in Minecraft for example took away the whine entirely (it could push several thousand FPS at times). I've also noticed that it depends on the type of load; Getting 2000 FPS makes a very aggressive whine, while something like RDR high settings hardly produces anything you'd call a whine, but it's still there. I'm assuming this means a specific section of the card is being affected if frame volume has a different effect than frame data. I have yet to do any GPU hardware doctoring of my own, so I'd like to check here for advice on how to fix this, if there is a fix for it.
the pc guy
https://linustechtips.com/topic/1359575-high-load-coil-whine/
Whine at 2,000 fps should be expected from virtually any graphics card.
You might just be very sensitive to things like that. I've personally never experienced it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1359575-high-load-coil-whine/#findComment-14892877
The speakers do heavily exaggerate it. Before I had them hooked up, the 2000FPS whine was barely louder than the RDR whine is currently, at around 3 feet away. It never stutters outside of what you'd expect with Minecraft, so my speakers probably are the main culprit...
the pc guy
https://linustechtips.com/topic/1359575-high-load-coil-whine/#findComment-14892881
What speakers are they?
https://linustechtips.com/topic/1359575-high-load-coil-whine/#findComment-14892889
