Budget (including currency): Around 1150 USD
Country: USA
Games, programs or workloads that it will be used for:
The computer will be used mostly for games like warzone, minecraft Java, and rocket leauge. It will also be used for some homework and 3D Modeling on autodesk. (Maybe VR if i get one.)
Other details
https://pcpartpicker.com/list/gwHX68
This is my first attempt at a PC build.
I am thinking of buying the pc before the end of the year but more likely in a month or 2.
I would like to play at 1440p at above 100 fps.
Due to the gpu shortage I dont have one included, but the processor I  picked has onboard graphics. I will look at a RTX series gpu after but that wont be part of the budget for now.
https://linustechtips.com/topic/1358050-first-time-building-pc/
Don't bother deciding on a build until you're ready to buy, part availability, pricing will all change.
As for the parts you picked:
  • Just for gaming there are better/cheaper choices like the i5/Ryzen 5.
  • Don't bother with that CPU cooler, spend just a little more on a Noctua.
  • I wouldn't get an MSI motherboard.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1358050-first-time-building-pc/#findComment-14882792
I'd look into the 5600x with stock cooler.  The 9900K is a bit old, though still amazing!!!!, but I'd not get it with all the current generations out now.
Buy Windows 10 Pro on Ebay or similar for under $10 if you want.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1358050-first-time-building-pc/#findComment-14882800
The ebay keys are random keys, and most random keys are 3$
And for the non random ones its around 20$ from sites like scdkey and you can use youtuber promo codes aswell
https://linustechtips.com/topic/1358050-first-time-building-pc/#findComment-14882811
PCPartPicker Part List: https://pcpartpicker.com/list/L7F7xc
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($269.99 @ Newegg)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($144.99 @ Amazon)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($108.99 @ Newegg)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Lenovo)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($111.57 @ Amazon)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($99.99 @ Newegg)
Total: $990.50
Generated by PCPartPicker 2021-07-20 10:53 EDT-0400
Since you have the budget, you could opt for a 5800x and/or 32gb of RAM.
https://linustechtips.com/topic/1358050-first-time-building-pc/#findComment-14882815
https://pcpartpicker.com/list/YtF7xc
Lets be real here, its either rainbow puke or good gpu at this price point
5600x 6 core, good pure gaming cpu cause good singlethread
The cooler is rather cheap cause i suspect you arent gonna oc
Same goes for board
No rainbow puke on ram unless you wanna spend an extra 20$ (ram is 72$)
Cant keep the rgb on the case, thatll be an extra 25-30$
50$ sounds small but add that to 775$ and youve got 825$ total which only leaves 325 for the gpu instead of 375
You want rainbows or actual performance?
Up to you but i heavily prefer performance over looks
https://linustechtips.com/topic/1358050-first-time-building-pc/#findComment-14882882
