need air cooler suggestion
Momenaut
I just installed a new 9700k system and used my old h212+ in the build but hit 94 degrees in the 3d mark time spy cpu benchmark which is too hot for my liking. I'm wondering what kind of upgrade to my temps I can expect with a better cooler and which ones will fit in my case (antec one.)
i5-3570K @4.3GHz Turbo w/ auto voltage
MSI Z77A-G45
Vengeance LP 2x4GB DDR3 2200MHz CL13
STRIX GTX 970 +180MHz Core clock +400MHz Memory Clock
MX500 500GB
CM h212+ w/ Cougar Vortex PWM 120mm @850 rpm
Lamptron FC9 \\ Cougar Turbine 120mm (4-pack) @800 rpm \\ NF-A12x15 PWM @1000 rpm
Antec One
Windows 10 Home
____________________________
ASUS VG248QE 3D @144Hz
G710+ w/ Corsair PBT doubleshot keycaps + Double o-ring mod \\ G502 Spectrum
AKG K240 Studio w/ FiiO Olympus \\ Logitech X-530 + X-240 = Ghetto 7.1
35 minutes ago, Momenaut said:
antec one
Dude, there's more than one antec case.
Get an NH-D15.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
Get an NH-D15.
rofl it's literally called antec "one"
MSI Z77A-G45
MX500 500GB
Antec One
Windows 10 Home
That was a lot funnier than it should have been 🙂
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
If you want cheap dual tower, then maybe Gelid Phantom Black.
Edit: maybe too high...?
Then Scythe Fuma 2
I edit my posts more often than not
I found the One!
Says you have a Max CPU Cooler Height of155 mm.
https://www.newegg.com/black-antec-gaming-series-atx-mid-tower/p/N82E16811129181
I had the be quiet! Dark Rock TF on a 6700k and it worked well.
https://www.bequiet.com/en/cpucooler/572
Quote
Quote
Quote
Quote
Is the cpu running at stock or are you oc'ing? What's the core voltage at under load?
I'm just running stock.
MSI Z77A-G45
MX500 500GB
Antec One
Windows 10 Home
That's strangely high for stock. Are you running default motherboard settings? If so, Multicore Enhancement may be enabled which is basically an auto-oc. Make sure that's disabled if you're planning to run at stock.
Have you tried reseating the cooler?
I was hoping not to have to reseat it. I shelled out for kryonaut and it's kind of a one shot go. I plan to run turbo and all that just no manual oc. Only settings I've touched are turning off the c states.
MSI Z77A-G45
MX500 500GB
Antec One
Windows 10 Home
An order of Kryonaut should be plenty for multiple applications. Did you use the entire tube?
What motherboard are you using? Did you check and see if there's such a setting enabled?
Turbo boosting is part of stock clocks but may be enhanced / raised through motherboard settings.
