so ive been having this issue since my last pc which had a r5 3600 and a rtx 2080 super and 16gb ram all powered by a 650w psu. i got a totally new pc with a rtx 3080 r7 5800x and 32gb ram powered with 850w psu
full specs of new pc:
rtx 3080 msi gaming x trio stock settings latest driver(new)
r7 5800x stock settings(new)
32gb ram 3200mhz corsair vengeance rgb pro(new) xmp is on
b550 tomahawk(new)
2x HDD 1x 1tb WD caviar green(very old) and 1x 2tb seagate barracuda(from previous system)
2x ssd 1x nvme 250gb(from previous system) 970 evo plus samsung and 1x sata m.2 450gb kingston (os drive which is new)
windows 10 pro activated
GX850 PSU from seasonic 80+ gold
g7 odyssey 1440p 240hz monitor
things ive tried:
reinstalling drivers using ddu
reseating gpu and pcie cables of gpu
try another gpu (1080 Ti) still had the stuttering and gpu power drop but happened less due to it running at way lower frames than my 3080
tried another ram
removed all the hdd and ssd that were from my old computer which are the 970 evo plus and the 2 hard drives and installed a clean copy of windows on my brand new kingston m.2 sata drive
turning off xmp
tweaking windows settings
checking if any background apps are running
turning off instant replay
using old gpu driver
making sure temps are ok
tweaking nvidia control panel settings
turning off gsync
turning off one of my 2 monitors
i have tried everything software related i think the issue is beyond software, i have a suspicion its my surge protector or my power outlet because im not convinced that my corsair tx650m from my old system and my gx850 psu from my current system are faulty.
here is a video of what happens:
i did try limiting frames to no avail but even if it worked, why limit the frames i have the same right as someone else who owns the same specs and doesnt need to limit frames. i dont know it just makes me annoyed that this happens to me and me only.
any help would be greatly appreciated, i can come discord if someone wants it would be much easier and i could send screenshots/videos of anything you require to help me
https://linustechtips.com/topic/1356370-gpu-power-drops-and-game-drops-frames/
Nice video. If you check the top left corner you can see that clockspeed remain stable.. FPS is also stable. So power dosen't matter
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
2 minutes ago, terminator5105 said:
hey i think that u r psu might be the problem
try changing it because a 650W for a rtx 2080super is cutting it close
Quote
@InfernalClawcan you make a longer video? 4 seconds of video are giving no information. As Nick already said your clockspeed and frames remain stable.
Ryzen 5 3600 | Gigabyte B550 Aorus Elite V2 | XFX 6700XT 319 Black | 16GB 3200Mhz CL16 | 600W BeQuiet  Pure Power 11
i dont know if you actually think its nice or its sarcasm anyways. are you sure? i mean thats from 300+ to less than 300 w in a second is weird and only happens to me amongst my friends
i did 4 seconds because video size becomes too large. will lower the quality
@SiNC_BZH hope this is enough. you can see right around the end of the video the game stutters or drops frames whatever you call it but it was noticeable on my end. the game freezes for like half a second and power drops
Is it weird thoug? My gpu does the same thing.. You can also see a massive difference when loading games.. When loading tarkov for example. My 1080 ti goes from 170W total powerdraw to 344W when in game. Also ingame it wil vary depending on level and diffeculty of the different areas of the map.
The thing is 30 series has massive voltage spikes and it could be that.. Have you tried going to nvidia control panel and setting maximum power.
Gaming PC:
Linux PC:
http://nvidia.s3.amazonaws.com/aid_3130/adaptive_performance.jpg
yes i already tried that. im seeing if my friend who has a 3090 gets the same problem or not
Could just be the game. I would try different games and compare
Gaming PC:
Linux PC:
36 minutes ago, InfernalClaw said:
I'm gonna be 100% honest. I don't see any problem.
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
18 minutes ago, InfernalClaw said:
also are you sure power dropping from 320 to 280 is normal?
Looks normal to me since there is no drop in FPS and/or frequency. A drop in power draw can have multiple reasons and don't necessarily mean something is wrong with the card and/or power delivery.
how many frames dropped would be dangerous. i notice it drops 10 frames or less sometimes
