Hello!, I need help regarding with my Nvidia Drivers, I reinstalled windows 10 on my Asus Laptop with a Geforce 920MX. I just noticed a while that my laptop was kinda sluggish and checked out in Task Manager that the GPU running is from the Intel CPU (Intel HD 620). I checked the Display adapters the only one showing is the HD 620. I got ahead and updated any windows system but still not showing any Nvidia drivers. I proceeded in manually installing the drivers but then Nvidia Installer failed. I ran out of options and in need of help in solving this problem. Thank you :>
https://linustechtips.com/topic/1356358-help-with-nvidia-drivers/
You have heaps of other non-installed devices, install them first.
Looks like you need your mobo chipset drivers installed, though you should really be able to install GPU drivers without them, might as well do that first though.
If that doesnt work, move on to cleaning your graphics drivers with the following and try again -
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
