corsair iCUE doesn't work - fans stuck at 100%
UPDATE: plugging and replugging the USB cable of the Lighting Node Pro's seemed to have worked.
Had a really long and quite bad day in reference to setting up a brand new system. First Google Chrome wouldn't sync my data, so I gave up and deleted everything (after backing up) and decided to start fresh - was literally trying and trying and trying for 3 straight hours to get it to sync. I then spent the next couple of hours uninstalling and reinstalling lighting control applications. So, the day is coming to an end and I've barely done anything with my brand new rig! Everything including the build went very smoothly, which is why it's kind of funny for me to get stuck at what are essentially silly software issues. Sometimes that's how it is.. Anyways, hopefully this helps some one
