Need help DOWNGRADING Graphics Card (gtx 1050 to gtx 210)
Solved by Bananasplit_00,
This is the way I'd do it:
Download the installer for the latest nvidia drivers supported by that card from NVIDIAs website
Run Display Driver Uninstaller
Power down and swap the cards
Boot into Windows, the basic display driver from M$ will be used automatically
Now run the driver installer you fetched in the first step and you're done. You've now got a clean install of the best driver for your new card, this is how I'd go about any graphics card swap.
