I’m trying to figure out whether I’ll be able to add a graphics card to my pc, here are the specs.
hp prodesk 600 g2 sff motherboard
i5 6600k
200w hp power supply
WD Blue 1TV 3.5” 7200RPM HDD
silverstone case fan
Cooler master i70C intel LGA-115x socket cpu cooler
I’m looking at getting a Asus GeForce GT 1030, 2GB
https://linustechtips.com/topic/1354279-power-consumption-for-cheap-pc/
i5 6600k
Swap the psu, if it cant fit youll have to modify the case or just swap case altogether
Keep in mind, this is an HP desktop, they often have weird power connectors on the motherboard that are not standard. You probably cannot switch it out.
i5 6600k
You probably can, since that card only draws board power. But be aware: you will not get any decent performance from that GT1030. That card shouldnt even exist. If you are planning to add this card for gaming, don't. If its just for video output, it should work.
Swap the board for a decent z170 or a b150 that can set multi
Hp prob uses some garbage h110 or q150 board with garbage vrms that cant oc the i5 6600k
Of course it is a garbage motherboard.
I wouldn't recommend swapping it out. If you swap the motherboard you need to:
- Get a new PSU, because the HP one has proprietary connectors.
- Get a new case potentially, because those motherboards have weird form factors, and standard boards might not even fit the case or front IO
At a certain point, you are just building a new PC altogether. Why would you spend money on a new motherboard for an old 4-core 6600K? Either stick with the current PC (perhaps slot in that GPU), or just sell it and build a new system.
Mobo is the most expensive part here but then again b150 boards exist and you can prob oc somewhat on them maybe via bios or throttlestop, a decent 600w psu is like 70$ and you can just toss it in whatever case you can find whether it be a 3$ scrap case or go caseless and shove the pc on top of a cardboard box
