Audio Help
Solved by GotchaGod,
It's really stupid too cause it also has static while playing genshin which uses only 30% of my gpu. I'm just not going to monitor my voice unless I have to cause it always has static. No combination of cables + ports + interfaces + mics + drivers + having recently upgraded to a new PC altogether fixed the static. Guess I'm also gonna have to deal with static coming though my mic as well when I play genshin. I give up.
Edit: Fixed the issue (of the static coming through my mic) by turning the graphics down and restarting so at least it isn't static while recording genshin. (I have a 3060, I have no idea why genshin has this issue)
TLDR: XLR mics have so many problems and I'm tired of dealing with it.
