My PS5 controller vibrates randomly while charging.
Plugged in via USB C to my PC to charge.
I was done gaming, and had dropped my controller on my desk to charge, when I thought there was an earthquake... It was just the haptic feedback going nuts in my controller. Is there anything I can do to prevent this? It's a bit obnoxious at times. o.x
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
it's in the middle of a dream dont disturb it
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
  • 2 weeks later...
2 hours ago, Npiet1 said:
Cable still good? Have you tried plugging it in the ps5?
Mine vibrates for a second when I plug it in or out.
I actually don't have a PS5, I just use the controller with my PC.
I've tried 4 different cables, it seems to be extremely random when it vibrates. It also tends to vibrate really really lightly most of the time, but sometimes it goes 100%. o.O
