Water cooling a GPU, help needed.
Go to solution Solved by danalog,
Water cooling a GPU is definitely a very high end solution, and is very much an investment. But it is worth it if you can pay for it. The best way to watercool it is with a waterblock.
So let's say you decided that you would like to improve the cooling of your gpu, what would be a better solution, upgraded gpu fans or water cooling?
If water cooling is the way it would be a gpu only cooling system as I already have a cpu aio installed. Also, what would be the easiest way to water cool it?
Card: Zotac twin edge OC 3070
https://linustechtips.com/topic/1353251-water-cooling-a-gpu-help-needed/
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
And if your on more of the budget side then you can get something like this. ⬇️
1. Asiahorse Graphic Card Cooler 3 x 92mm Fan with Led Frame,Support ASUS Aura SYNC/MSI Mystic Sync/ASROCK Aura RGB/GIGABYTE RGB Fusion (5V 3 Pin Addressable headers) https://smile.amazon.com/dp/B08LD6PNN4/ref=cm_sw_r_cp_api_glt_fabc_6HA2TFM9373CTB8J2WB8
2. Jonsbo Aluminum VGA Graphic Card Cooler - Graphic Card Fans - 3 x 80mm Fans with SATA+Aura 4PIN Connector VF-1 https://smile.amazon.com/dp/B07P9Y18HB/ref=cm_sw_r_cp_api_glt_fabc_EP766PFAKEVVDF4KAQY7
3. anidees Graphic Card Cooler 3 x 80mm PWM Fan, Support Aura SYNC/MSI Mystic Sync/ASROCK Aura RGB/GIGABYTE RGB Fusion (5V 3 Pin Addressable headers ONLY) PCI Mount Bracket with Remote- AI-GP-CL https://smile.amazon.com/dp/B07Y6CY6GL/ref=cm_sw_r_cp_api_glt_fabc_50R405QBVRRDCT4MY9P6?_encoding=UTF8&psc=1
there's also the hybrid mod by slapping and cpu block on it and cooling the vrm with a fan or heatsinks
hybrid with aio
cheap
pro
geto
aftermarket cooler
NVIDIA GeForce GTX 1080 tested with aftermarket cooler | VideoCardz.com
Edited by thrasher_565
