Grammarly not Functioning Properly and Backup Codes Question/Concern
Solved by colonel_mortis,
Grammarly doesn't work properly in the editor, and causes random extra stuff to get added to your posts, so we disable it.
It is expected that if you have any 2FA methods enabled, you are prompted for them every time you log in - that is the main place that it's used. When you're running low on codes, you should get a warning about it, but I don't remember if there are failsafes beyond that. If someone did manage to run out, in the worst case they could use the forum support link to get help recovering access. That is definitely not the intended way to use backup codes though.
