Hey it's Austin I have an issue first off I tried to put my motherboard into PC part picker.com and it just wasn't coming up with my bill so I need help with what PCU I should use in the waters for future graphics card for my build. So far
1.MUSETEX 6 PCS × LED ARGB Fans Pre-Installed 2 PCS × USB 3.0 Ports ATX Tower Case  I already have this
2.ASRock B450 Steel Legend AM4 AMD Promontory B450 SATA 6Gb/s ATX AMD Motherboard I already have this bought from newegg.com $89
3.ryzen 5 3400g justed waiting for it to come in the mail .bought from Mercari $180
4.Help!!! not sure on what budget ram that's good I have $60
5.Help!!! not sure what nvme pcei to use budget $60-$80
6.Help!!! psu not sure but I definitely want 80+ bronze or better fully modular I'm ready for a graphics card in the future.budget $70-$80
7.future graphics card not sure but my budget would be around $200-$300
I keep reading all these reviews on PSU just keeps blowing up or not working I really need to know what wattage is the best for this build haven't got a graphics card yet but I will when I get off the money for a low price graphics card I'm not looking for anything crazy but I do need help!!🤣
Edited: I also need Wi-Fi can a USB Wi-Fi after work or do I have to have a Wi-Fi card on the motherboard
https://linustechtips.com/topic/1351878-help-psu-help/
9 minutes ago, adarw said:
what is your overall budget and did you buy anything yet?
1 minute ago, adarw said:
how much did you pay for each lol
80 for the case
180 for the ryzen 5 3400g
89 for the ASRock b450 steel legend ATX motherboard
24 minutes ago, HeyitsAustin said:
Hey it's Austin I know an issue first off I tried to put my motherboard into PC part picker.com and it just wasn't coming up with my bill so I need help with what PCU I should use in the waters for future graphics card for my build. So far
3.ryzen 5 3400g
I keep reading all these reviews on PSU just keep s blowing up or not working from the dead girl I really need to know what wattage is the best for this build haven't got a graphics card yet but I will when I get off the money for a low price graphics card I'm not looking for anything crazy but I do be help!!🤣
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14837980
If you can find a corsair RM650 in your budget that would be the best option. Otherwise you're not getting a good modular PSU, the best would be a Be Quiet System Power 9 CM, but it's semi-modular. Shouldn't be an issue as only the required cables are stuck on it.
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14838008
Okay thanks I want to see if anyone else has any other ideas but I will definitely keep this in mind and look it up and do my research
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14838022
30 minutes ago, HeyitsAustin said:
Well I already have the case.I bought the ryzen 5 3400g just waiting for it and I already have the motherboard asRock b450 steel legend. As for the budget goes I only have about $200-250 left for the PSU, ram, and nvme
here I did to match your budget https://pcpartpicker.com/list/gZV2y4
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14838031
Moved to the New Builds & Planning section. It's a better spot to get general help for building a new PC and choosing all the parts to go with it.
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14839008
  • 2 weeks later...
On 6/29/2021 at 6:35 AM, adarw said:
ram
m.2 ssd
psu
I got everything on computer running I had the jumper cable to the CMOS connected and didn't realize it all I did was unplug it in the bios came up and then I had a friend install Windows 10 on a USB and voila I had a working computer
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14859353
nice!
|:Insert something funny:|
https://linustechtips.com/topic/1351878-help-psu-help/#findComment-14860333
