I have trouble setting up swag as a proxy on unraid
Go to solution Solved by Reikasa_,
I managed to fix it by adding these two attached lines into the site config of swag under appdata/swag/nginx/site-configs/default
Hello smart people,
I have unraid running on a server here.
My plan is to have my instance of nextcloud accessible over http/https.
I have already setup a dyndns service, the necessary portforwarding and swag as a proxy to the point that I reach the swag startup page when I try to connect over my domain.
Now I struggle to forward that connection to my nextcloud instance...
I tried following a few tutorials and I always think I edit all the necessary configs the right way, but I never managed to connect to nextcloud.
Sometimes I wouldn't be able to access nextcloud at all anymore and sometimes I couldn't access the swag page anymore because of a "502 bad gateway" error.
Any help is very much appreciated!
best regards
On 6/28/2021 at 7:02 AM, Reikasa_ said:
Hello smart people,
best regards
So the Swag docker already comes with an example config for Nextcloud.
Have you connected to the docker and gone to /config/nginx/proxy-confs and found the existing sample config?
You need to rename it from nextcloud.<domain>.conf.sample to nextcloud.<domain>.conf for Swag/Nginx to read it. Also check the variables are correct in the config.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO | 12 x 8TB HGST Ultrastar He10 (WD Whitelabel) | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
Yes I did try using that file.
I tried both renaming it as nextcloud.<insert my domain name>.conf and just nextcloud.subdomain.conf.
Of course I also edited the content according to tutorials I found online.
But I still only get to the swag config site that tells me I should set it up properly.
I'll attach the config file of swag.
I did not yet edit the nextcloud config, but from what I understand that should only matter for logging in, I should still get further than swag if it is properly setup.
Nice work 👍
I was going to point out that that nextcloud.conf points to an internal name of https://nextcloud in Swag, so there must be another proxy_pass configuration in a default/global config for configuring the actual hostname/ip
  • 3 weeks later...
What does the IP 192.168.178.47 reference for I have tried this with both the IP of the SWAG docker container and the Unraid server and it just stops working completely instead of the 502 error.
