Gigabyte B450M DS3H V2 Micro ATX AM4 Motherboard | $69.99
NZXT H510 ATX Mid Tower Case | $66.99
AMD Ryzen 3 1200 (14nm) 3.1 GHz Quad-Core Processor | $89.37
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler | $44.99
Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory | $74.99
Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply | $84.99
MSI GeForce GT 710 1 GB Video Card US | $64.90
Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G | $7.15
PC BUILD
503.37$
YOUR THOUGHTS FIRST TIMER HEAR
https://linustechtips.com/topic/1351167-my-first-pc-build/
Ditch the gt 710 and get decent apu like 2400g or 3400g
The stock cooler probably enough but if you want and care about temps then get id cooling sse 224 xt it's cheaper
Or just spen little more to get ethier scythe fuma 2
Get phanteks p360a, it's around the same price but much, much better
Also, you didn't have any storage...
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14832840
-= Topic moved to New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14833304
Arctic silver 5 isnt needed, the cooler should come with thermal paste or if you want thermal paste get gd900, cheap and really good for the money.
The board is eh, maybe a slightly better board
Rubbish case with rubbish airflow, get the p300a or p360a.
Ditch that stupid 710
Swap for a 2200g or 3200g apu
And 80$ is excessive for a bronze psu, a 600w evga gd psu is like 60$ on amazon
And if you want to stick with the ryzen 3 1200, get an hd 6350 as a display adapter, around 5-10$ on ebay
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14833371
But will the build I have placed will it work for the time I can upgrade
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14833510
As long as you fix these  v v v
Your build should be fine
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14834441
PCPartPicker Part List
CPU: Intel Core i5-10400 2.9 GHz 6-Core Processor  ($173.98 @ Newegg) use the iGPU.
Motherboard: MSI MAG B460 TORPEDO ATX LGA1200 Motherboard  ($109.99 @ B&H)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($72.97 @ Amazon)
Case: Metallic Gear Neo Silent ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Total: $446.92
Generated by PCPartPicker 2021-06-27 22:19 EDT-0400
https://linustechtips.com/topic/1351167-my-first-pc-build/#findComment-14834700
