My brain does not work... Help?
Go to solution Solved by WolfDeville,
Its so expensive for MOAR. :D
 This. Just stick with what's on it man.
Hey there,
My brain gets confused, THIS. As I understand if I mount it on my r9 270x, it doesen't need ramsinks? Does the backplate do it all? I thought ramsinks need to be ON the chip itself. Somebody please give relief to my poor brain :(
If I mount the backplate on the card, do i need ramsinks or not? ( Including the VRM sink things and stuff )
This is my card
https://linustechtips.com/topic/135066-my-brain-does-not-work-help/
Actually no. I live in a dangerous neighborhood tho. I could go and ask somebody to reboot it for me.
Ok, let me know how it goes. My brain feels like it needs a reboot every now and then.
(Sorry for not answering your question)
waffle waffle waffle on and on and on
I don't think it's worth it for a R9 270x but if you wanna go for it then go for it, should work just fine. :3
It's a                        Hajimimashite
Sleeping Cat             Watashi wa Miku Hatsune Desu :3
Mjau (^w^)                Linus wa kawaii desu! Hai ka XD
Sell the 270 you have and buy one with a better cooler.
I use the Sapphire Dual X and it is amazing. 60'C Max when gaming and at about 30% fan speed.
Please don't buy that very expensive huge heatsink for the little 270.
Nothing to see here - move along.
