Hello, fellow gamers and pc builders, I am a console gamer that got into PC cuz it looks way better than console and also all my friends are on PC, but that's beside the point. So while I was gaming on RDO (red dead redemption online), it came to a point where I had to decide between the looks of the game and performance. Now after a few minutes of trying to find the fine line between both I just decided to pick the overuse decision and when with the looks over performance. Now after playing about 4 to 5 hours playing on high/medium I am getting fed up with getting away lower than 40 FPS. So I search up a few things and I came across this, overclock my GPU (GTX 1060 3GB) or add more ram. At this point, I don't know what to do to get a little more performance. My goal is just to have a simple good looking gameplay with an average FPS of 40 or higher without having to see glitches or lag issues with my graphics or having to tell if that shoe is a rock or an actual shoe. Your help in anyway would be very helpful.  🙂
My system is composed of:
  • CPU:
AMD Ryzen 5 2600
  • RAM:
16.0GB Dual-Channel 1064MHz (15-15-15-36)
  • Motherboard:
ASRock B450M Pro4 (AM4)
  • Graphics:
NVIDIA GeForce GTX 1060 3GB (EVGA)
  • Storage:
232GB Samsung SSD 860 EVO 250GB (SATA (SSD))
1863GB Seagate ST2000DM008-2FR102 (SATA (SSD))
All running on Windows 10 64-bit
https://linustechtips.com/topic/1350333-need-some-help-with-deciding-on-something/
What RAM is that exactly?  It's running at 2133Mhz, but it may be able to higher with XMP.  More than 16GB of RAM won't make RDO run faster, tested that with my system.
OCing the 1060 may net you 4-5 fps max, you're looking at bringing some settings down.  Look for an online guide that knows what settings to tweak to get the most bang.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
It's also important to put up what resolution you normally play at. I assume 1080p but if you are playing at 1440p (or even some rather intensive games at 1080p like RDR2 or CP2077) your GPU won't be able to handle even medium textures, afaik.
Like dedayog said try to find out what RAM that is, even if your GPU is capped at the memory limit it should switch over to system memory, which is very likely to be the cause of graphical issues and inconsistent FPS. If you can turn on XMP it may be smoother than without.
Dedayog has some good points.
I don't have RDR2 so I don't know how demanding the game is on your VRAM. But considering it is a fairly new game I would say your biggest problem is that 3GB VRAM buffer.
So overclocking your GPU will probably not give much performance.
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
The ram I am using is dual Ripjaws DDR4 sticks at 3200 but it's running at 2133. Should I max that out? Also, bringing some setting does improve FPS but not by much like 2 or 3 and if I bring them down more it makes the game look kinda ugly. But if I got to play on a low setting to stop some buffering I think ima do that.
I normally play on 1920x1200 resolution. What is XMP?
Alright so u saying I should get a hole new GPU? hahah
Go into the BIOS of your machine and enable DOCP.  It's AMD's version of Intel's XMP.  They are the names for what the BIOS does to overclock RAM.  2133 is the base speed, but since you bought 3200MHz you can get the BIOD to run it as such.
You should be able to find a "profile" for your RAM speed in your BIOS.  Not sure exactly where, BIOS' can be slightly different.  It'll net you a few fps.
As for settings... I mention a guide because other people have painstakingly tweaked them all and measured the gains, they know which ones to change for the biggest fps improvements which you may not know.  It's not just a factor of lowering them all.
OnePlus Ecosystem:
3D Printing:
Thx you and everyone else very much for the help I will do what you said and see the difference.
It would help but at the current GPU market not the smartest solution.
I would start with the in-game settings and try to play around with those to see which ones change performance a lot and which don't. Find a good mixture of settings that make it so that you are satisfied with the performance while not skimping too much down on graphics.
Also in the in-game video settings there should be a bar that shows how much VRAM your settings need which should give you an indication if your settings are too high or not.
Pretty much this, but to add to it the most likely settings to turn down will be anything related to textures and SSAO, if RDO has that. They should contribute to that VRAM usage and performance quite heavily. I'd start with medium and work your way down on those two, then up with the rest till you see what looks good enough for you.
If you were to get a reasonable upgrade for your current GPU it would be something around 400 dollars right now. Bit insane, but that's actually a bit lower than usual.
