Guys please help me, I have a laptop with a core i7 7500U 2.9 ghz base clock, but when ever I launch a game and start playing the speed drops to around 2.2 - 0.9 ghz, although the temps would not exceed 55 degrees celsius, can you please help me, I have enabled windows best performance power plan, reinstalled windows and updated the bios, though, nothing seems to work, I really need your help, thank you.
Edit : I have solved the problem, it turned out to be a power limit problem because I had the battery unplugged, after I plugged it the cpu
continued boosting normally, thanks 😄 .
Edited by HD4K
found the solution
https://linustechtips.com/topic/1350287-need-help-with-my-cpu/
Which game?
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1350287-need-help-with-my-cpu/#findComment-14825733
52 minutes ago, HD4K said:
any game, I tested it in fortnite, valorant, apex legends and rogue company.
How much FPS are you on?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1350287-need-help-with-my-cpu/#findComment-14825885
