Budget (including currency): $2-3000 a bit more if really needed
Country: USA
Games, programs or workloads that it will be used for: ARK, The Isle, Minecraft, two-pc streaming.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): ABS TUF - Intel i7-8700 - GeForce GTX 1080 - 16GB DDR4 - 240GB SSD - 2TB HDD - Gaming Desktop PC prebuild from Newegg, (2j Elgato 4k60 pro(not installed), prebuild has been upgraded with Samsung 970 nvme ssd. I want to make this the streaming computer, then build a new gaming rig.
I obviously neglected to check my motherboard for proper pci slots to support the capture cards, so now I need a new motherboard with big enough slots for those! Do you think the processor I have will be fine encoding all of that video (DLSR and Game PC) if I yank the 1080 to put in a new gaming rig until the current GPU market cools down? I have a 360mm AIO coming for the CPU to help cool it down from the extra work it’s going to be asked to do. Any Motherboard suggestions that have the at least 2 PCIe x4 slots for the capture cards along with a slot to put the 1080 back into once the new machine gets it’s own card? I haven’t checked yet, but if I don’t have onboard graphics in this CPU, what is a good replacement?
https://linustechtips.com/topic/1350094-need-mobo-replacement-second-comp-advice/
Well CPU Encoding encoding will be a lot slower than using the NVENC Codec with the 1080.
Look for an Asrock board as a hint. I have several different ones in use, never let me down.
I currently stream 1080p without an additional capture pc to youtube with my old system (see signature) without a problem. But then I don't have a cam connected, only audio right now.
Cheers
Ang
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
4 minutes ago, Rhinopkc said:
Thanks. Any suggestions on motherboards that have at least two PCIe x4 (for the two capture cards) and on PCIe x16 for the 1080?
You can use the current motherboard and use a PCIe riser
If my answer is correct or is helpful please mark it as the solution. Quote me in your post to summon me. Beware that after summoning me ill never leave.
https://www.asus.com/us/Motherboards-Components/Motherboards/All-series/TUF-B360M-PLUS-GAMING/ Is my current motherboard. I only have x1 slots, if I plug an x4 card in there on a riser, won’t it run too slow?
Yes, you would need another motherboard. What would be your budget for the motherboard
