Weird sound with my WD Elements 4 TB
P-J
Hello everyone,
Recently when I kept my external HDD (WD Elements 4TB) plugged in, my computer would not boot, and when I plugged it back after booting, sometimes I would have no issues reading and writing from/to it, sometimes it wouldn't respond. In such cases I could hear the sound I've recorded and attached to my message.
Should I start making copies of what's inside because it's an early sign of failure or it's nothing too worrying ?
Thanks !
HDD Sound.m4a
That sounds like the drive can't stay spinning properly, most likely because of a lack of power. Are you using the original cable that came with the drive? Also, are you using it with a USB hub?
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
Thanks for your reply, I've kept the original cable, I've tried on a hub which was connected from a USB-C output on my laptop with, supposedly, a 100 W of power delivery, but it did this sound.
The same happened on a regular USB type A (3.0) output on my laptop. I haven't considered the fact that the laptop was not plugged in and was using its battery, I'll try with the laptop plugged in.
Try with a couple of cables on a desktop PC if you can, but yes it seems it's dying and fails to spin up or calibrate.
F@H
GPD Win 2
I got 6TB WD Elements few months ago, and it does the same sound randomly for me, especially when I do recording with nvidia shadowplay to that hard drive and/or maybe something to do with the hot temperature during summer.
I did some hd tune testing and while SMART seems ok, there is some massive spikes during benchmark, I'd recommend you try the scan too.
I think the hard drive is defective, mine even has its own power supply.
I didn't expect this from WD ☹️
This sounds to me like the it doesn't have enough power for plates to move,if your power source is okay I'd assume there is an issue in electronic circuit board.
I'd make a copy of files just in case.
Are you using genuine adapter which came with the drive,and an usb 3.0 cable?
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
