Minecraft problem
Go to solution Solved by Coombzy,
I remember there being an issue with the new AMD driver a friend of mine had the same issue he used this tutorial to fix it.
Hey guys I have a problem with minecraft where I can only see signs, clouds and the tops of torches. Everything else is invisible (hitboxes detectable). I have re installed minecraft, the launcher, graphic drivers (multiple versions) and even java, the problem persists. I also tried using different resource packs. I don't have the time to do a fresh install of windows so I was wondering if this was a known problem or if I should just tinker.
This doesn't happen any other pc of mine
If it helps my PC config is an i5 2320 with a HD6990 and 8gigs or gskill ram.
Any help would be awesome,it is such a strange problem I have no idea what is wrong.
post-1028-0-11724500-1396482943_thumb.pn
post-1028-0-06430900-1396482954_thumb.pn
post-1028-0-34391000-1396482971_thumb.pn
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/134909-minecraft-problem/
Happens to me occasionally. Re-installing the drivers usually fix it but also messing around with your Minecraft graphics settings sometimes help. Get the Optifine mod so you are able to mess around with more graphical settings which may help.
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
https://linustechtips.com/topic/134909-minecraft-problem/#findComment-1794490
Thanks, that worked. :D
https://linustechtips.com/topic/134909-minecraft-problem/#findComment-1795309
