Hello, i want undervolt my GPU Nvidia RTX 2060 Super WindForce 8gb because my temps go with every game to 88-89 degree.
The problem is in MSI Afterburner when i CTRL+F nothing happends and yes i unlocked it in settings.
I tried everything from installing newest drivers to gpu and afterburner but nothing.. same goes for Aorus Engine nothing opens.
(sory for bad english)
Thanks for help.
https://linustechtips.com/topic/1348956-rtx-2060-super-undervolting-problem/
Undervolting your GPU may result in lost clocks, which means lost performance.
Can you focus on improving the air flow of your case instead?
What type of case are you using and how many fans are installed?
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
