Negative pressure coolant system.  The concept has been around for a very long time in other things.  There are certain limitations.  One thing it can do is detect the presence of a leak by detecting pressure change. By definition means a loop cannot be open.  This concept is older than computer watercooling.  I assume there is a reason it is not used.
