Budget (including currency): Around $650 before tax
Country: USA
Games, programs or workloads that it will be used for: Minecraft, Genshin Impact, Anno 1800, School
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p 60-75hz
This is the first time I've attempted to build a computer and wanted to make sure I'm not forgetting something or making some crucial mistake here. Actually not for myself, but my brother and so having something that doesn't require much tinkering when setup and being like a laptop connected to a monitor essentially is ideal. Already have most of the peripherals with the exception of a webcam, but that's not in the budget. I tried to come up with something in pcpartpicker with the help of an article (https://www.digitaltrends.com/computing/best-500-pc-gaming-build/).
https://pcpartpicker.com/list/ntLXwz
I added windows because brother doesn't want a pirated/trial version. Motherboard was also changed to have one with wifi. It's not a ton of storage and if/when it runs out planning to add a hard drive. I also changed the ram a bit to a single stick because it was cheaper, but it's the same otherwise.
Other than that it's the same as the article, but the article is a month old and I did change some stuff so just wanted to check in to see if anything's wrong before continuing. I'll continue to look for a better deal on the ram but other than that is everything decent for the price?
https://linustechtips.com/topic/1348644-first-build-for-brother/
Not a great time to be building right now, but I would recommend going used
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
I know gpu's are rough right now but it seems like this older cpu is fine for the most part? The integrated graphics should be good enough I thought at least. Most of the other stuff seemed in stock as well. I know used would probably be good with the budget and stuff but the "client" here wouldn't be happy with that.
Please convince him otherwise. That's a good chunk of your budget that could be put to much better use on physical parts.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
Linux. It's really not that hard. Steam games work fine through WINE/Proton. Minecraft's official launcher has support. Windows apps work through WINE. There are so many beginner-friendly distros that can be styled like Windows 10.
Just now, RandomNerd99 said:
Well, I'll try but I'm not sure. Plus some of these games/applications might not run right?
First of all, as they are most likely a Windows user, look for a distro which uses the KDE plasma desktop environment. Probably Kubuntu. You can always use the iso's "Live" ("Try <distro name>") option to get a feel for it before installation.
Minecraft: Supported natively
Genshin Impact: May be supported via Lutris or WINE
Anno 1800: Supported via Lutris
All steam games: Supported by Steam Proton
Zoom: Supported natively
Major browsers (chrome, firefox, brave, etc): Supported natively
But it's up to you 🤷‍♂️
That list is ok other than wasting money on a windows 10 key, if you really want an activated windows badly then you can go to a site like scdkey for cheap windows keys, they are considerably more expesive than the ebay windows keys (3$ ebay vs 10-20$ scdkey) but you are guaranteed to get the lisence you wanted like win 10 pro license whereas on ebay you just get sent a random license so you dont know what you are gonna get.
Though i highly suggest just swapping to linux cause windows 10 is really slow due to all the bloat installed by microsoft especially on older or low end systems.
I use windows 7 cause i really hate w10, though i still have to use w10 cause i use a laptop, and good god it is slow as hell, even a freaking decade old lga 775 dualcore would crush this thing. I bet if i could install w7 then there would be a pretty big difference in load times esp on low end or systems that use hdds.
And i think linux is better than w7 in terms of performance enhancing depending on which distro you have.
