Hi there
I bought a new 970 evo plus 2TB m.2 NVMe drive. When I installed it into my main system (in my profile), I could configure it easily enough into a drive. The problem came when I tried to install samsungs drivers on it. And when looking at samsung magician, it does not detect neither of my m.2 drives (I have a pre-existing 970 plus 500gb). After a lot of messages with the correct samsung tech support email, the person on the other end said that my system had detected the 2 TB drive as a USB-device. And followed by saying: "
Please check with Microsoft the settings together, it seems the SSD detected ans USB device. "
It was at this also, that I realised that my 500Gb boot drive was neither running with samsungs drivers. Althought it appears as a 970 evo plus in my task manager. The new 2 TB drive appears only as a microsoft storage device.
Any ideas on how I could get this solved?
I could contact the retailer, but at this point samsung´ s support was not great.
https://linustechtips.com/topic/1348208-samsung-970-evo-plus-driver-issues/
I can't give you a solution to your problem, but you don't need drivers for your SSDs. They are plug any play devices.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
4 hours ago, FinOxy said:
Well, yes and no
They work, but aren't as fast nor efficent
At least with SSD's that's actually not how it works.
Sure, you might want the latest drivers for GPU, Chipset, BIOS and maybe a sound card but that's about it. Not every component needs drivers to work as intended.
Well
Does windows drivers support and run NVMe 1.3?
That is a seperate driver, I think
