Warzone Issues still with 5900x & EVGA RTX 3080 XC3 | June 16, 2021
kyookyoo
I was wondering if anyone knows what the issue I may be having. I can't seem to pinpoint why warzone itself is having issues for my system when every other game i'm able to play above 180 FPS on max or almost max setting on 1440p.
TLDR of parts: (Full list below)
CPU: 5900X
RAM: 2x16GB 3600MHz CL16
GPU: RTX 3080
PSU: 750W / 1000W (tried both)
Monitor: 240Hz 1440p
Things to note/tried:
- I have latest BIOS, chipset, & GPU drivers as on June 16, 2021
- PBO enabled
- XMP enabled
- PCIE x16 lane is set to GEN4
- GPU is on stock EVGA settings
- Have tried with a 1000W PSU with no difference
- Have repasted and reseated my CPU cooler
- Have tried a Noctua NHD15
- I have reformatted Win10 & reinstalled drivers
My issues:
- I remember getting 150-180 fps on MAX 1440p settings during my first two months with both components back in Nov-Dec 2020.
- Now I can barely get 100-120fps and medium settings at 1440p and I have to restart my game at least every other game or every game of warzone because my frames will dip below 80 fps.
- I have tried ctrl+windows+shift+B which helps a little, but does not get me back to 120fps.
- When DLSS was released to Warzone, I was getting 150-180 fps on quality settings, but turned it off due to optic issues found my JGOD, now the new DLSS fix gets me 110-150 fps, which I find very strange
- I also have stuttering issues & packet loss (which I think is tied to me playing on wifi which I cant get around), the stuttering here n there, idk why it happens still
Any help would be extremely appreciated.
Here is my build below
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG Strix X570-I Gaming Mini ITX AM4 Motherboard
Memory: G.Skill Trident Z Royal 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive
Storage: Seagate IronWolf NAS 6 TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce RTX 3080 10 GB XC3 BLACK GAMING Video Card
Case: Lian Li O11 Dynamic Mini ATX Mid Tower Case
Power Supply: Corsair SF 750 W 80+ Platinum Certified Fully Modular SFX Power Supply
Monitor: Samsung Odyssey G7 LC32G75TQSNXZA 31.5" 2560x1440 240 Hz Monitor
Custom: Lian Li O11D Mini 1X PCI-E 16 X4.0 Riser
I have barely dabbled in Warzone, but:
Do you have it streaming textures? I enabled that because use an ethernet cable straight from my router and have solid download, if you're on wifi you'd want to make sure that's disabled.
Can't really reference performance as I run a different resolution, I'm running mostly higher settings + balanced DLSS (IIRC, if I remember I'll boot it up again tonight) at 4K with a 6950X and 2060 Super, pull a solid 60fps.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
If u have rgb software such as icue or nzxt cam running try turning it off then test the game. I tried it today and warzone has never run so smooth.
Did you turn RTX on?🤣 Dips requiring a restart to fix sounds like a genuine problem somewhere though. Reset all settings and reload shaders, after that I'd try reinstalling the game if only Warzone has issues.
Just checked, my 3090 at 1440p everything maxed, RTX/DLSS off gets 160-200 FPS in nuketown, averaging 175-185ish just measuring by eye
Yes I do, I have ASUS Armory Crate & Corsair iCUE open. But I've also played with it off which sadly doesnt make a difference :(. Glad it works well for you though!
Nope, no RTX on. I've tried messing with all the other settings with DLSS on/off. My max with everything on lowest settings is around 180fps, when looking online people are getting 200+ on lowest settings on 1440p with 5900x + 3080.
Also I only have this issue with Modern Warfare / Warzone now. Cold War is zero issues.
Packet drops could also well be server sided and have nothing to do with your rig or ISP. The most interesting part is the FPS drops people with latest gen hardware experienced in few weeks. Wouldn't be surprised at all if in the end it turns out that the game mines crypto in the background when it detects an RTX or RX GPU.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
