Minecraft startup script help (english)
On 6/13/2021 at 10:57 AM, Sauron said:If you're on wifi then you can make it so Windows automatically reconnects to the network as soon as the wifi adapter is available - just check the "Connect automatically" box. If you're on wired you don't even need to set that up, it happens automatically.
I don't know about minecraft, but I've come across a few programs that would fail to load if the internet connection started working after the program was launched.
On 6/13/2021 at 10:52 AM, LittleCham said:I'm using windows 10 but I would like a script that could also check other things like making sure internet is connected. So I don't have to go to it and connect to internet anytime my computer restarts.
You can try a batch file, and putting it in the startup folder (which gets run automatically)
e.g.
@echo off :CheckInternet REM Calling Ping, where ping waits for 5 seconds REM Ping will set errorlevel 1 if its not connected REM If no internet if found, try finding it again (so it repeats checking about every 30 seconds, until you stop it or it finds a connection) REM if connection is found goto the launchProgram echo Attempting to find internet connection ping www.google.com -n 1 -w 1000 if errorlevel 1 ( TIMEOUT /T 30 goto CheckInternet ) if errorlevel 0 ( goto LaunchProgram ) :LaunchProgram echo Launching program [PUT YOUR LAUNCH CODE HERE...something like C:\MineCraft\start.exe] pause
