Has anyone had any problems with their 3080 ti?
On 6/15/2021 at 10:10 PM, KREWLIFE said:When you put your 2070 back in and use it for a while the issues stop?
On 6/16/2021 at 9:26 AM, Slizzo said:Individual power cables used? No daisy chains to the video card?
On 6/16/2021 at 9:33 AM, shaz2sxy said:what PSU, the 3080ti takes a lot more power the the 2070
With my 2070 I had a stable overclock to my i9 10900K @ 4.9Ghz but with the 3080 Ti I've experienced more PC crashes than with any other PC I've used or built.
I reset most of the settings for my i9 in my BIOS settings and the crashing has ceased. I'm think that I just had a really unstable overclock for whatever reason. I can look more into that at another date.
The GPU is using 2 separate cables coming directly from the GPU, one cable with both connectors in use and the second cable with only one connector in use. The GPU requires a 12pin connection in total.
Right now for my PSU, I'm running a CORSAIR HX Series HX1200 - 80 Plus Platinum.
So I don't think a lack of power is an issue unless the distribution of power being equally distributed with this PSU is a problem I'm unaware of.(This was last minute purchase when I was building my rig because PSU's were sold out everywhere and expensive in the U.S.)
