rx 5700 xt temperature issues after replacing thermal pads
Solved by Bitter,
Yeah, that thermal compound between the die and cold plate should not look like that when you take it off. It should look like you didn't put enough on there because all the extra is pushed out the sides and you can almost see bare die and bare cold plate. What you have is 100% a case of low mounting pressure, as you've found out likely due to the thermal pads being too thick. When you can afford it, I suggest you get some .5mm pads or hit up Gigabyte to get the exact pad part number you need so you can either get those pads or work backward from that number to determine the exact thickness needed.
