I guess this is probably what you'll have to get, A USB to ARGB Hub like this one from coolermaster. https://www.coolermaster.com/catalog/coolers/rgb-accessories/argb-led-controller/, That or a new motherboard. Truth is there just aren't any (apparent) compact USB to 1x or 2x ARGB headers on the market. Shame really, you could perhaps control ARGB device with an Arduino's GPIO header maybe if you didn't wanna buy a ARGB Hub and had sufficient programming knowledge to do so.
Discord : https://discord.gg/AuFFAA5FAp
PC Spexifimacations :
- AMD Ryzen 7 5800x 8c/16t Zen3 Desktop Processor
- GeForce RTX 3080 EAGLE OC 10G (rev. 2.0)
- G.SKill Ripjaws 32GB (4x8) 3200MHz CL16
- Gigabyte X470 Aorus Gaming 7 Wifi (Super Sexy Indeed)
- 1TB WD Blue NVMe M.2 SSD + 4TB 2.5" 7200RPM HDD
- Corsair RM750x 750 Watt 80 PLUS Gold Certified Fully Modular PSU
- Coolermaster TD500 Mesh-G (with all fans)
https://linustechtips.com/topic/1345815-mortar-max-argb/#findComment-14792100
10 hours ago, medyobano said:
Recently just bought the Mortar Max. I have a set of 3 fans hooked up to a fan hub. The connector of the hub is only through ARGB. Sadly, the Mortar Max does not have one. What can I do to sync my fans and motherboard? Thanks.
you can try this but it will make the argb fans act like rgb fans
5v device to 12v mb header
otherwise you need an usb 2.0 controller or an manual controller
Edited by thrasher_565
https://linustechtips.com/topic/1345815-mortar-max-argb/#findComment-14792541
31 minutes ago, Kautzer said:
as the title says i would like to know whether or not the B450M MORTAR MAX has 3pin ARGB headers/pins/ports/whatever its called since the case I'm planning on getting for my build has argb on the case+argb fans. because I cannot find any info about it online, sorry if it's a dumb question
Oh sorry, No according to the user manual it doesn't appear to have any ARGB Headers on it, just the 2 standard 12v ones.image.png.6ca41e7d8b6b8cc7d6cc9e5a139d6def.png
https://linustechtips.com/topic/1345815-mortar-max-argb/#findComment-14792823
