Custom Water Loop - Los Angeles
Go to solution Solved by airborne spoon,
the only way to learn to do something is to do it. Trial and error, my first water loop i had to do every bend like 3 times. its an artform and requires practice and patience, but once you figure it out you can make some gnarly loop designs.
I'm only about 3'ish hours from LA but i don't have the free time to come down there to do that for you.
Hello everyone,
I've recently taken on the endeavor of building my first custom loop computer.
Though I've run into an issue lately and that is time and some lack of experience.
rough specs:
Case: lian li o11 dynamic xl
Dark Hero MOB
32GB CL14 3600
5950x
Strix 3090
All water-cooling parts are EKWB.
Is there anyone in the Los Angeles area that has experience with building and custom water cooling that I can pay to complete this build for me?
As it stands the parts have been sitting in this case for about the last month with almost zero progression, just due to a time restriction.
You can travel to my office and work here, it's a 20,000 sqft building with plenty of space for yourself OR I can bring everything to you if necessary though building it here in the office would be easiest.
I should have just about every fitting or extension you need as well as all of the acrylic tubing you could possibly use. Heat gun, bending aid, even a mini desk top power cut off saw, and entire repair business I-Fixit kit along with their Manta kit.
Honestly, I would like custom sleeved cables, I don't know how to even start doing that though so if you have experience with that and can help me order customer cables even better. If for some reason I don't have something we need, you think I need or you recommend then I will buy it. I built a custom bracket for the O11XL and have fit two of their distro plates in the case.
I am looking for someone that will treat this almost like their personal rig and help me make it the most bad ass thing possible.
 Photo attached.
https://linustechtips.com/topic/1345598-custom-water-loop-los-angeles/
