Phone is fast PC is not
spellmanuk
So i just got upgraded to FTTP yesterday with a 900Mbps but garenteed 450Mbps down.
however my PC is the other side of the house so im forced to use Wi-Fi i have an Asus RT-AC5300 Router and can get 370 to 400 Mbps on My iphone 12 in the eaxct same spot as the wifi antenna for my PC but my PC can barely crack 100 Mbps both are on the 5GHz Chanel AC wifi i made sure there is no other interfering networks on the same chanel as mine but no luck control panel also says i have a 300Mbps link with the router itself so im extra confused. All drivers up to date on the PC even tried forgetting the wifi and readding it tried moving the wifi antenna around slightly (its one of those thats on a slight extantion cable)
any ideas appreciated
I lurk a lot
Make and model of wireless adapter?
Intel(R) Dual Band Wireless-AC 3168
I lurk a lot
That's your limiting factor. Speed maxes out at 433Mbps and it's a 1x1 device.
Need to upgrade if you want to attain higher speeds (look into Intel AX210), but keep in mind that achieving gigabit on WiFi won't always be possible.
You didnt read what i said it cant even do 100Mbps right now i am fine with it "only" going 433Mbps look at the screenshots i uploaded its crapping out at 34 Mbps right now
I lurk a lot
Yes, but no adapter actually ever reaches its maximum throughput in real-life conditions. You have to go beyond that because there are usually more optimizations that can take full advantage of the bandwidth.
What are the WiFi settings for the 5GHz radio on the wireless router?
its not the router every other device on my network can acive at least 300Mpbs (laptop xbox phone ipad ect) you cant say that this is expected when its only getting 12% of the same speed as other devices in the same location
I lurk a lot
Are all of your other devices using the Intel AC-3168 and achieving better speeds?
I'm not even saying it's the router. I just asked what were the WiFi settings on it.
Edit:
Also, how far is this PC from the wireless router? Have you tried installing the latest Intel drivers?
Is it on board wifi or an add in card? Often onboard wifi on cheaper boards is pretty basic and this is not uncommon. You have 4/5 bars which means signal strentgh is already dropping so nothing odd ere
The thing is, I've seen cases where my phone could do twice the speed of my PC in the same location.  To fix that I had to double the channel width on 5Ghz from 80Mhz to 160Mhz.  That's just how weird WiFi can be sometimes.
Just upgrading from an AX200 to an AX210 WiFi adapter gave me 100Mbit more speed.  As mentioned, the 3168 is a low-end card so upgrading it to a high-end AX210 could make a huge difference.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
